Fault Finding | on ElectriciansForums
Discuss Fault Finding in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
E.E.I
Hemel Hempstead
Hi,
Does anybody have any tips or tricks on how to find where a break in electric UFH cables.
I was thinking of using a tone generator and hoping to trace the tone until it stops.
had a client once, lots of electric ufh laid under a posh marble floor and busted insulation readings after job done. he called helpline provided by manufacturer, they came out with I believe a high voltage source and a FLIR camera, spotted the fault in no time, one floor tile got lifted, they repaired the faulty bit with some special splices..
One of our very regular customers does a fault finding service, he tends to use a Thermal Imaging camera and then pinpoint the break from the cold spot in the cable.
Reply to Fault Finding in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
This is an RSS feed of thread: Gas or Water Pipe? Look to find cause of damp in wall. Content of the thread: Hi all, First time post so please...
You need a power supply of a certain type and voltage then. 2 can play at this game!
