Fault finding | on ElectriciansForums
Discuss Fault finding in the Electrical Course Trainees Only area at ElectriciansForums.net
High Tower
Nearly Esteemed
Birmingham
Ok, one of the hardest things you guys will have to deal with as sparks will always be fault finding, it really only does get easier with experience, so........... im going to describe some of the faults i have been to.
i would like your theory's, ideas and suspicions, how you would go about testing to confirm your theoreys and any rectifications.
Please remember there are no stupid answers. soooooooo
two bedroom terrace house, front door opens into dining room, leads to living room, leads to kitchen.
Cu s in dining room to the right of the front door.
6 way very early crabtree 60898, only 4 circuits used, 2 power and 1 shower.
Fault was catastrophic loss of lighting, breaker was in the on position and working fine, whole house in darkness apart from dining room which was working.
over to you guys
it sounds like the entire lighting is run of the 1 mcb so that's why it all went off except the dining room (should upgrade to a split board haha), as the board is in the dining room i would assume that the cable goes from the board to the dining room lights to start with then onto the kitchen then upstairs, there is probily a loose connection either on the live or the neutral wire in between the last light that is on in the dining room and the first light that is off in the kitchen, the first thing i would do is a visual inspection on the ceiling rose from the last light that is working to see if there are any loose cables if there are no loose connections that i can see (i wouldn't touch any cables at the moment as they are still live and this would not comply with eawr reg 12 "i think") i would go to the next light and check that ceiling rose if i could not see any thing i would go to the last point on the circuit and do a quick check to see if the line conductor is live with a voltage indicator if there was a live feed then it would make me believe that the fault is on the return path(neutral) so i would then go to the board isolate it then put a link between live and neutral (r1/rn) or put both cables in chock block then go to the furthest point and do a r1/rn continuity test and work my way back till i got a reading then i would no the problem was in between that fitting and the next fitting, so now i have narrowed it down i would check the connections and probily find a loose wire.
sorry for the essay answer
Im going to let others join in before i digress the rest.
I wont say anything HT. It may take a few days before others join in mate, its not the busiest of forum sections.
Good idea for a thread HT, I'll post one up from a fault find call out from yesterday and post up a picture of the fault. I wonder if Trev can post up fault finding scenarios as well, I'll ask him.
Yeah mate the more the merrier, just think its only fair to let em run for a little while so a few people can have a pop at it, yours and trevs would be great too
Lol so I take it that I am wrong! haha
Assume nothng ! first rule of faultfinding, comes just before "the DIY client is probably lying"
As i said i will let it sit for a while in case there is any more interest.
Can I ask if it's a single or 3-phase CU?
Domestic single dwellings in the UK are single phase mate unless special permission is given by the local authority or it is divided into flats that demand more than the incoming supply cable can hold. In this case it will be a single phase supply. :)
Lmao, I was going to say I'm not telling you because of your superior skill and knowledge, you don't need the help, but I'm not telling you because I don't wanna lol
*tears*
I'm still at a loss how '....superior skill and knowledge' and 'you don't need the help' ended up as 'Nope not telling na na na na na na' ;)
Reply to Fault finding in the Electrical Course Trainees Only area at ElectriciansForums.net
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
