Hi every one just wanted to ask a few questions about testing for faults at college.
On Thursdays I was in the workshop and they brought a board out with a 1x ring final 2x 2way lighting and a radial socket circuits all wired to a consumer unit but it had been wired up with a few separate switches so they could switch one of the separate switches and it would make a fault on one of the circuits and we had to find the fault but my question is what is the sequence that I should use to find faults I thought start with a global ir test but if that shows no fault what would I do next would I have to go through each circuit seperatly and do a continuity and r1 r2 test?
