fault | on ElectriciansForums
Discuss fault in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
1983
good eveing every1 i was at a job the other day with a mate helping out on sum cctvs in a wearhouse.
i was asked 2 look at one of them flood lights on the wall as it was hanging the onwer said that since it has been hanging everytime he trys 2 switch them on it trips.
1st i isloted that light and flicked the msb 2 c if it will trip and it still did haveing a look at the d/b there is a fuse for the flood lights but i noticed it was wired to a timer it also has an relay wired nxt 2 it.
there is one mcb for the fllod lights and one for the timer. when the mcb for the lights are on the lights dnt work when both the mcb for the timer and lights are on it trips the msb for the lights.
any ideas where the fault may be? im feeling a short circuit sumwhere between the timer and relay all help much appreicated thanks in advance and sorry bout the long discreption
The dualling of the mcbs will be so that the timer carries only the switching current of a contactor
The contactor on its own mcb supplies the lights via the load side of that contactor
So if you switch on the timer mcb on its own it likely will stay on because it doesn't feed the lights
When the mcb for the lights is switched on by itself,it likely will carry no load so wont trip
When the timer mcb is then switched on and in turn switches the contactor coil to the closed position,a fault on that lighting circuit will then show itself, because the current can then flow through the closed contacts of the contactor through the fault and pop the mcb
Reply to fault in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
