Ok guys, if were getting these out too quick and overwhelming you guys then say!
So........
Im working in a florist, its in a arcade in the city centre, each unit is supplied with a 16mm SWA from a Ryefield board in the plant room, each board is a metalclad 10 way Merlin Gerin, main switch only CU. circuit arrangement is not important in this case.
I have to fit new 4x2 mods, in the suspended ceiling. Turn off MCBfor the circuit. the lights go off, but placing a volt stick on the cable still shows voltage. i must stress that i hadnt got to the point of safe isolation by this point.
Why??
So........
Why??
