Faulty dewalt line laser DW087 | on ElectriciansForums
Discuss Faulty dewalt line laser DW087 in the UK Electrical Forum area at ElectriciansForums.net
K
KevinRich
Hi I have a problem with my dewalt line laser DW087
It was all working fine until one day turning it on the horizontal laser line has split into 3 line instead off the one line. Because the line has split into 3 distinct lines the brightness of the laser has dropped to the point it's unusable. The vertical line is still as good as ever. Has anyone come across this fault, I have taken it apart and inspected and cleaned the lens but it's still the same. I can't afford a new one just yet with this recession. Any advise would be appreciated.
Hi smuggler thanks for reply, do you think this would be a calibration issue. When the laser is put in horizontal mode the laser line is split into 3 lines all about 3mm apart. It's like the laser line is being deflected through a prism or something. because there are now 3 lines it's only 1/3 as bright.
Reply to Faulty dewalt line laser DW087 in the UK Electrical Forum area at ElectriciansForums.net
Try disconnecting the "central heating off" wire from terminal 2 and insulate it (eg Wago connector or choc block or similar) and tuck it out of...
2 3
4K
