what you guys thing, on a light i was changing, 230v L-N and 114v L-E and 114 between N-E so 114v on the earth or there abouts, when i crawled in the garage attic seems to go towards heating circuit..... not 100% tho
Discuss faulty electrics ltd. in the Australia area at ElectriciansForums.net
The thing with measuring a voltage is that you need to know exactly what the voltage is 'with respect to'.what you guys thing, on a light i was changing, 230v L-N and 114v L-E and 114 between N-E so 114v on the earth or there abouts, when i crawled in the garage attic seems to go towards heating circuit..... not 100% tho
and not saying i know more, but if was a fault at transformer, would all earths be revealing this fault.... thanks guys ... im just going to rewire the cable route and hopefully find the correct cables and terminate in junction box or remove
Hi I=p/u
I have had this problem mate !! The earth for the lighting was disconnected so when you are testing to earth theres no earth path hence the low volts i got a reading of 234v line to neutral then line to cpc was 114v and neutral to cpc 114v the cpc of the lighting circuit had come out of the earth bar in the ccu not saying its your problem but worth checking bud completly my fault as i had just changed the board
Richard
Reply to faulty electrics ltd. in the Australia area at ElectriciansForums.net
