Faulty fluoro bulb light | on ElectriciansForums
Discuss Faulty fluoro bulb light in the Lighting Forum area at ElectriciansForums.net
Sambo1
Brisbane
I have a circular fluoro light, 40 watts. It just stopped working today, but then at other times during the day it would come back on. Thinking it was a faulty bulb i put in another bulb (admittedly i don;t know how old it is). Now with the other bulb the light does the same, sometimes it works and sometimes it doesn;t. Any idea why the light work intermittently. It is not flickering at all.
Low voltage can cause this
Faulty starter can cause this
Faulty ballast can cause this.
I would start by changing the starter (if there is one)
They are cheep and easy to change.
After that, maybe check the voltage coming into the light fitting.
Reply to Faulty fluoro bulb light in the Lighting Forum area at ElectriciansForums.net
You as well! Popcorn and beer on hand plus a day off, I'm ready! :)
Neutral and live
