Dompal
Hi
My father in law has a series of 5 mains powered LED down lighters in his dinning room stop working all at the same time. There are other LED's in his kitchen next to the dinning room which all work fine.
Would there be one breaker for each series of LED's on the fuse board, could this be the issue?
Forgive my ignorance but I've not been in the trade for over 10 years and not worked with LED's.
Any help would be much appreciated.
If they all stopped at the same time then I would either suspect the light switch of failing, especially if it is a dimmer switch, or possibly a high voltage surge, but that should have affected other lights as well.
as ^^^^^. or a possible failed connection at or before 1st light. either L or N. first check for voltage at switch (L-N and L-E) then at lights.
Faulty LED downlighters
Dompal,
Farmelectrics,
