Faulty Megger 1740. | on ElectriciansForums
Discuss Faulty Megger 1740. in the UK Electrical Forum area at ElectriciansForums.net
Wiltshire
On an EICR today my Megger crackled on a pscc test then started giving a 20ka reading (which giving the EFLI was 0.19 and had a corresponding PEFC seems impossible) and claiming it was overheating. From that point onwards it would no longer perform either a 2 hi or 3 lo loop test and seemed to be inconsistent on r1+r2 readings. Has anyone else had this happen ?
Megger 15 series in my opinion are the best. Had a few 17 series that have put out err 23 codes. This is s an internal clock component issue, had another err29 fault. Internal components issue. Every time back to megger 280 a pop. . I now have purchased second hand 15 series and they last. Megger knows about these issue but claim they are not a common fault. Look ๐Ÿ‘€ n line people are mentioning the dreaded err codes.
Reply to Faulty Megger 1740. in the UK Electrical Forum area at ElectriciansForums.net
Well done. Leads sound a bit high btw mine are 0.07 when warmed up. Rcd uplift - I either calculate Zs, or use the kitcher trick. See
  • [Speak๐Ÿ—ฃ๏ธ AA]โ„ขHow do I speak to American customer service?24&7!!Fast!!Service
    ๐“ฃ๐“ธ ๐“ฝ๐“ช๐“ต๐“ด ๐“ฝ๐“ธ ๐“ช ๐“๐“ถ๐“ฎ๐“ป๐“ฒ๐“ฌ๐“ช๐“ท ๐“๐“ฒ๐“ป๐“ต๐“ฒ๐“ท๐“ฎ๐“ผ ๐“ต๐“ฒ๐“ฟ๐“ฎ ๐—ฟ๐—ฒ๐—ฝ๐—ฟ๐—ฒ๐˜€๐—ฒ๐—ป๐˜๐—ฎ๐˜๐—ถ๐˜ƒ๐—ฒ ๐“ฒ๐“ท ๐“ช ๐“บ๐“พ๐“ฒ๐“ฌ๐“ด ๐“ฝ๐“ฒ๐“ถ๐“ฎ, ๐”‚๐“ธ๐“พ ๐“ฌ๐“ช๐“ท ๐“ฒ๐“ท๐“ฒ๐“ฝ๐“ฒ๐“ช๐“ฝ๐“ฎ ๐“ช ๐“ป๐“ฎ๐“บ๐“พ๐“ฎ๐“ผ๐“ฝ...
  • What is the refundable option on ๐”ผxpedia? Cancellation Policy ยฎ
    What is the cancellation policy for ๐”ผxpedia? ๐”ผ๐•ฉ๐•ก๐•–๐••๐•š๐•’ ๐• ๐•—๐•—๐•–๐•ฃ๐•ค ๐•’ ๐•˜๐•–๐•Ÿ๐•–๐•ฃ๐•’๐• ๐Ÿค๐Ÿฆ-๐•™๐• ๐•ฆ๐•ฃ ๐•”๐•’๐•Ÿ๐•”๐•–๐•๐•๐•’๐•ฅ๐•š๐• ๐•Ÿ...
  • [[Official~Expert]] Contact QuickBooks Desktop Support Customer Service HElp QB Support
    To contact QuickBooks Desktop Support via phone, dial โœ…๐Ÿ“ž +1-844-881-9274 +1-844-881-9274 or #...
