J
Jeff7777
Hi I am not a electrician but wondered if anyone could help. This morning I put the washing machine on and about a hour later my rcd tripped out. I could smell a burning smell from behind the washing machine so pulled it out. Behind is a double socket with a hole burnt on it. Further inspection the neutral terminal had melted but the wires weren't that hot and checked and them for heat and breaks back to the rcd which seemed ok. I replaced the socket and all seems fine. Could it be the original socket was fault all could there be another problem. The original socket was fitted about 3 yrs ago and seemed ok until today.
many thanks.
many thanks.
