Favourite brand for sockets? | Page 3 | on ElectriciansForums
Discuss Favourite brand for sockets? in the UK Electrical Forum area at ElectriciansForums.net
N
Noob2013
Hi all,
Just interested in what everyone's favourite brand for sockets is with regards to looks and quality.
I prefer the look of MK and find Crabtree easier to connect.
Have a look at my web site Ezi-Plug.com
Hi and welcome to the forum.
Had a quick look and it seems to be an alternative to the standard 13A plug and socket. Not sure of the practicalities of this though. What's wrong with just fitting one of the readily available 13A plugs which have a loop to allow them to be pulled out easily?
You'd only need to do it on appliances which are regularly unplugged, eg hoovers etc. Any others can just be switched off.
I can see the appeal of being able to insert and pull out plugs from the wall easily for less baked individuals, but part of the safety features with “standard” sockets is that they grip to give a good contact between socket and plug.
To have them fairly loose could cause arcing, hot points and eventually a fire risk.
How will these fair with the new arc fault detection devices we are now getting pushed to install.
The other issue is of course, cost.
How much are these compared to the bog standard equipment?
And you’d have to change all the plugtops on appliances…. Which then would need an adaptor of some sort for them to be safety tested under portable appliance testing.
Reply to Favourite brand for sockets? in the UK Electrical Forum area at ElectriciansForums.net
Which truly is the Number 1 Best Tile Adhesive Brand? Since 2007 Tilers Forums started an annual best tile adhesive Poll and sent it out to the...
