Evening peeps so today I started fitting my heated seat matts to my st150 seats. I’ve taken my power from fuse box with a fuse splice I’ve used the electric window one which has a 30amp rated fuse I need two feeds for the each heated seat is it ok to split that one power connection to feed both seats or will it draw too much current don’t want a bonfire ?
Current Draw: 3 Amps on Low Heat Setting and 5 Amps on High Setting per Seat
Much appreciated
Much appreciated
