A
aj2304
Hi all,
im a recently qualified electrician who is looking for a bit of advice. A friend of mine (also an electrician) has asked for my help on one of his jobs. The job is feeding a sub main distribution board which is located in the porch area. It is only feeding two circuits, one being a 32a small ring circuit in the shed in the garden, and the other being a 6a lighting circuit feeding the light in the porch. The problem I'm having is that my friend is wanting to feed the board using a 10mm PVC twin running it under the flooring from the main fuse board. He's saying that he thinks it's fine running it straight from board to board. However I'm sure that along the lines somewhere you have to run it through a spur? The run is only around 10-15 metres from board to board but I just wanted to check before my name would be going on the test sheet. Sorry if this is a dumb question however I don't do much domestic work in my job.
thanks for any help.
