Ferret inspection camera | on ElectriciansForums
Discuss Ferret inspection camera in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Sussex
Hi I recently discovered Ferret wifi cableless cameras with wifi extender, does anyone know of any similar smaller cameras on the market with a good wifi signal for cavities etc. Thanks
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Well it's arrived.Downloaded the app and connected it using wi-fi with no problems at all.It has very bright intergrated lights and comes with quite a few attachments like a hook,magnet and periscope. This is the quality of the photos.[ElectriciansForums.net] Ferret inspection camera
Excuse the cobwebs but the picture is very good.
I will try it out next week on various projects and report back.
several on amazon similar but a lot cheaper. know you get what you pay for, but has anyone experience of these cheaper alternatives, trending ÂŁ30 to ÂŁ60?
Got a few different cameras the Easyview is a good inspection camera been using it for about 3 years now and I also have the 20m camera to go with it, although it is sold as a pipe and drain camera I have used it in stud walls and inaccessible roof voids. I also have a couple of these cameras in different lengths that can be used with a phone or on a tablet which is how I generally use it because of the bigger screen
Just bought the ferret, ÂŁ115 at Edmundsons. It is good used a few times already but...it does warn you it will lose the wi fi behind metallic materials and so on. So I was fishing a wire for my stereo in the van and got the hook over some cables I did not want to. I tried untangling but the wi fi went off in the middle of it due to metal in the bulkhead and had to do it by feel instead so a bit disappointed at the wi fi strength at the price. Still early days we shall see on the job proper.
Reply to Ferret inspection camera in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Try to use a catenary wire for better support for your outdoor cable. I'd recommend TP-Link ceiling-mounted access points, which are good options...
    • Winner
AVR's and Generators in a rack??? And only at 7.5kW?? What are you actually trying to build?
