M
MTI
Hi all, please can anyone clear up the following:
domestic install:
existing CU in very tight kitchen cupboard and full to brim. Tncs supply on other side of wall in external meter cupboard (newish build)
1) new sub is needed to very large shed/office in garden area.
am i permited to run my sub through external semi recessed cabinet?
2) 16th split load CU is full and in cupboard which is only just wide enough to house it. No chance of getting to tails to split with blocks as they back entry from meter cupboard on other side of wall (external cabinet) If CU is full and fairly heavily loaded and cannot access tails in house, how and where would you connect new swa sub?
obviously new RCD main switch to feed sub - would you use dp rcd or switch fuse isolator?
taking into account its to feed a shed.
3) not sure where to read up on this but i have seen blocks on the tails before in external cupboards. This layout however has straight uncut tails from cut out to CU in house. I doubt im permited to put my isolator in external cabinet with blocks on tails?
4) what about smoke detectors in very large shed/office? its new install and obviously a self contained building which is open plan. Would you put them in? im thinking yes as new install and plus will contain tons of pc's and electricals etc. Go on, tell me they need to be linked to the house too haha! sorry!
dont mean to sound daft guys but any help is appreciated as im working in the dark here until i get my books back tomorrow.
cheers in advance
client wants a price today
domestic install:
cheers in advance
