SafetyEICR
Few faults that got alarm bells ringing today.
3P+N MCCB Panel fed directly from busbar chamber wired in 3 x single 120mm s.w.a cables with 25mm pvc/pvc neutral conductor. MCCB Panel feeds plant equipment, no submains.
I'm right in thinking neutral conductor should be equal phase c.s.a unless particular conditions are met?
Do harmonics come into the equaltion?
Also main switch for MCCB rated to 250a. OCP for MCCB panel is 400a 88.2 in the busbar main switch, Would you warrant this a code?
