P
p11jor
Went to look at a job today (on the move) and going to return tomorrow.....house is a 17th board but mixed wiring.....the shower is on the right hand side RCD, when the ISO switch is turned on everything is fine, but soon as the shower draws any power Then the RCD on the left trips but the one protecting the shower doesn't......? Also the fire alarm (brand new install from why I can gather) is showing power supply fault.....I flicked the fuse spare to off and it went dead so thinking could this be the battery backups being dead ? Also when taking the cover off the board the lights started flicker so checked the bus bar and it was tightened metal/plastic on a couple of the circuits (i did fix this whilst there) also there was a snapped nuetral bar from the plastic holder and no ip ratings around the top and bottom of board, so I come to the conclusion of a bad install, I have never seen the case of the shower fault before? Has anyone else? I am returning in the morning to do a PIR and possibly fix these faults if they agree to paying out again. Any suggestions would be helpful. Thanks
