Hi All,
Client called recently. Saying few spotlights not working, halfway all 3 of them, living room-kitchen only two works out of 15. Flat newly built, last inspection 2019. I've been told by client that bulbs gone more or less st the same time. There was nothing obvious as I've checked, lights switches for possible loose connections(feed at switch), check Voltage at few lights fittings and Zs at last tails, readings are good. I've changed all bulbs, so client has light now.
But I'm curious what might cause to blow few led lights at the same time? Surge? Bad product batch? Lights in other rooms are fine, same lights.
The brand in question is Luceco GU10 lights
