Fibreglass loft insulation | on ElectriciansForums
Discuss Fibreglass loft insulation in the UK Electrical Forum area at ElectriciansForums.net
K
KevinS
Following on from a previous post where the OP was slightly paranoid that he was going to die due to drilling one hole is what he thought was asbestos.
does anyone know, or read a report about what fibreglass loft insulation is doing to us.
is fibreglass inhalation going to be the disease of the future?
i for one hate the stuff.
the alternative foil stuff is £400 a roll and this glass wool is subsidised to £3 a roll....so guess what will be staying ....in the USA the foil is about £30 a roll, was seriously thinking if I would like to import a load of it for re-doing my mums house and granddads house ....but would probably get taxed at about 3,000% by the jobsworths here on arrival...
I can see MDF being a problem thanks to the likes of 'Changing Rooms' on the telly, where they make everything out of it and encourage people to use it at home, where they're unlikely to bother with extraction or even a dust mask.
Some chippy at work was saying plywood isn't much good for you either, thanks to the Formaldehyde in the glue - working alongside a chippy is about as good for you as chain-smoking.
I was at an asbestos course in work and its unbelievable the amount of places u find it, the guy was saying it used to be in crayola crayons, carpet underlay and also a thin form of paper was an asbestos sheet for a few examples! The amount of things he told us that contained it was scary. I'm only 26 n been a spark for 9 years n from day one ive been exposed to it. The loose brown papery insulation is really bad for u and almost always contains it. He also mentioned mdf has been linked to various cancers and he recons in a few years it'll be the new asbestos. Supposedly from exposure asbestos related diseases always kill and can develop anytime from 15 to 60 years after contamination!! Ur body does threw a natural process and cells breaking down get rid of the fibres but as with anything else the more there are the higher the chance there is of something nasty developing.
very 90's! think the last show aired in 2004 iirc...
I was never really 'into' it, partly because they didn't seem to 'improve' people's homes but create novelty themed rooms which you couldn't actually live in. I think there was one programme where they painted some woman's bedroom red with animal print fabric everywhere. They took her into the room and removed the blindfold and she was absolutely mortified - she said it looked like "a -----'s boudoir".
If 'Changing Rooms' isn't on the telly any more I'm sure there is some other similar programme that's taken it's place. Do they use MDF on DIY SOS?
We use loads of fiberglass at work and It can't be doing people any good. They used to have some sort of 'spray on' insulation didn't they? was that as bad or was it just too expensive?
Same here, although we use fibreglass chopped strand mat rather than insulation - I spent a year working in a fibreglass moulding shop where the air is filled with particles of it for you to breathe in along with a cocktail of fumes from resins, gelcoat, styrene etc which apart from making your clothes stink, cause ailments such as lethargy, forgetfulness and cancer. They had made a token attempt at extraction but all the fans seemed to be filled with fibreglass dust so didn't seem to do much.
I think after a while you build up a kind of immunity, but to start with it makes your arms itch like hell.
Reply to Fibreglass loft insulation in the UK Electrical Forum area at ElectriciansForums.net
Sounds more positive.
