Fike zone faults | on ElectriciansForums
Discuss Fike zone faults in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
henlow
Hi all
I have installed twinflexpro fire detection system and getting zone faults ,please have look at attached video.
Any idea how I can clear the fault,
Thank you
[automerge]1575322451[/automerge]
View attachment IMG_0763.MOV
Have you programmed it using their software. What was the problem with the Twinflex panel you replaced.
Why haven't you connected the cpcs to the appropriate terminals.
Have you programmed it by way of the usb port.
[/QUOT
It is replacement penal I do not how to programme ,I tried to follow its manual. but I cant get it right.
[/QUOT
no I did not use software as I had couple of suggestion which recommended I do not need to use sofware
i have been suggested there is no need to use software.
Basically I do now how to program it.the old was faulty and it was showing EOL missing,I am not competent but I am an Elecrition trainee ,I thought there is no need to put cpcs in appropriate terminals as old one was in connector blocks so I did same.
Thanks again for your help
CPCs should always be correctly connected, just because someone previously didn't and created a dangerous situation it does not mean that you should copy them.
Reply to Fike zone faults in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Exactly as James mentioned but he didn't point out that Integration with AI requires dynamic symbiotic engagement and often results in a lower...
Thank you..... & did have all the fan isolator/ fuse in same plate (click) so quinetic wouldn't worked on this occasion
