T
TPES
Just a few questions on a test scenario, quite hard to explain in writing but hopefully you'll understand.
If a detached building is fed from an older type fuse with SWA, then the detached building is TT'd, (Earth Rod)
what details am i recording on the cert for....
Supply characteristics...
Would i tick TT on the cert as this is the newley installed earthing arrangment for distribution circuit to the garage im testing? or would it be the original Earthing arrangements back at Main CU?
Also maximum demand
PFC
Ze
Would this be taken from the sum main?
Ze for the new Distribution circuit at submain aswell as PFC and Max Demand..?
Characteristics of primary supply overcurrent protective device(s)
BSEN
Type
Current Rating
Short Cct Capicity
Is this the main fuse coming into the Main Dis board at the intake OR is it the fuse within the main CU that is feeding the distribution cct to the Submain?
I could work my way through the whole certificate..
an example of a cert filled in with a distribution cct from main CU, with TT at submain would make it alot clearer for me.
Schedule of test results...
For the SWA feeding submain. how would i get a Zs reading as the earth is not used from the SWA as i am using TT for the submain.
Soz if ive confused you..
Also maximum demand
PFC
Ze
BSEN
Type
Current Rating
Short Cct Capicity
