F
freedomrun
If faced with a Domestic Final CCT (Lighting or S/O) and it has 2 sizes of T&E used, lets say a lighting CCT with 1.0mm used on some lights and 1.5mm used on other lights and if Zs & IR all complies - When writing out the Schedule of Test Results, what size Wiring conductor should be noted in column 4? Or should a remark be made in column 15 against this CCT stating that two sizes of cable are in the circuit. My question is really aimed at Lighting CCT's, but i guess two sizes of T&E are also found in S/O final CCT's now and again. Any ideas with regard to completing the Schedule of Test Results in relation to this please? Thanks in advance.
