Final Circuit conductor sizes in OSG 8.2 | on ElectriciansForums
Discuss Final Circuit conductor sizes in OSG 8.2 in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
ringer
Peterborough
Referring to pages 158-159 in the OSG
Table 8A
Type, OPD(A)
A1 Ring, 30 or 32 .......etc
8.2.3 Conductor size
....The as-installed current-carrying capacity Iz so calculated must not be less than:
20 A for ring circuit A1
Am I reading/interpreting this correctly when I say that the OSG is telling us you can have a RFC made up of cable with a capacity of 20A and an OCPD of 32A?
Table 8A
Type, OPD(A)
Yes because in theory a ring circuit is 2 x 2.5 in parallel which has a greater current carrying capacity than the 32A CPD:D
Of course. With it being a ring there is a cable either side of each accessory, and each cable is capable of carrying 20A so we actually have the capacity to carry 40A because in a parallel circuit each side carries the same quantity of current. (just thinking out loud here to make sure it sinks in - think about difference between ring and radial)
Thanks Ian - having a bit of a brain fade atm.
Distance also plays a part,one short leg of a ring going to high current appliances in say a kitchen, may carry quite a lot more than the second leg in the kitchen,which has to do a long tour of the house before getting back to the consumer unitIts important to try and equalise the loading for that problem to be minimised
Reply to Final Circuit conductor sizes in OSG 8.2 in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
