Final Circuits - Ring or Radial? | on ElectriciansForums
Discuss Final Circuits - Ring or Radial? in the UK Electrical Forum area at ElectriciansForums.net
O
OldskoolUpNorth
I was speaking to an Electrical Engineering suit not too long ago,
He reckons that there's talk of Ring Final Circuits being done away with and the preference to install Radials only.
Anyone else heard this little gem.
Whats the general preference of everyone for the two systems????
Anyone already doing just Radials??
Ta,
The getting rid of rings is a hoary chestnut that as been going around since I started my apprenticeship too many years ago now to bother with. As far as I'm aware there is no indication that they will be going in the near future.
Like all circuits for me the design of them would take many factors into consideration and whatever is the most appropriate for installation is the one I would use. I have to admit working overseas for many a year as well as back home I do prefer radials as a rule of thumb for kitchen appliances. I like the Fridge/freezer, W/M D/W on a separate radial, but the power sockets I would most likely leave as a ring, unless there is a good design reason not to.
I like ring mains in commercial/industrial as well. It seems now that a norm is if you have 7/9 16amp sockets then the modern sparks would install them on 7/9 radials, where I would use a ring main and tap off. Again though you would design the circuit as what is best for the situation
Got the impression there's a new discussion been started by those up on high about it.
We were on about industrial but he seemed to reckon it would apply to all sectors.
Sure your right tho malcolm if it's been banded around for that long.
I'm using the 'LearningLounge' for retraining. On the subject Ring/Radial, ring circuits are primarily used in the UK. Inroduced after WWII, when there was an acute shortage of copper. There are disadvanatges, it encourages the use of too many spured circuits, missing or loose connections (i.e. one leg of the ring) resulting in cable overloads & too many cable connections in terminals with potential for overheating.
Apparently the it may be discouraged in future wiring regs, coming from the EU.
In these days of cost and energy preservation,the ring possibly has a better case for keeping than ever before and in all sectors
I have heard nothing lately
It is an old old bone of contention, the anti ring section has always been around,apparently they argue it out at the IET regularly, more as a tradition I suspect
As i have said in the past, setting aside the load issues, the biggest problem I see with radials is loss of the cpc connection after the first and before the last point of use, this could be easily cured by making the radial a 'Dual Earth ' circuit which would require a 4 core cable or a separate cpc run with the 3 core..I can't see it happening
J
J
There's already a reg in BGB (can't remember the number off top of my head) but radials running over 10mA need seperate earth of 4mm or more - poss industrial but seeing as I don't do industrial I don't know.
Midwest again this Ring circuits only being used in the UK is another Hoary old chestnut. Yes in a domestic situation I can't think of another country that uses them, perhaps a few old colonial places, but in the main domestic circuits are radials .............
But here I design many a ring circuit in offices, especially for IT installations, where we use 4mm ring finals. As I highlighted in my OP in commercial/industrial a ring main around a building for BS 60309-2 sockets, appliances etc is a much more efficient cost effective solution that individual radial circuits from a DB
It's under the high integrity earthing section mainly used for IT where cumulative earth leakage is an issue
J
'Midwest again this Ring circuits only being used in the UK is another Hoary old chestnut' (sorry forgot to hit the reply with quote)
Only quoting what I have researched, but if you can show me differently? Wikipedia it, there are citations.
Reply to Final Circuits - Ring or Radial? in the UK Electrical Forum area at ElectriciansForums.net
    • Winner
Did anybody take this on at all? Just curious.
