i=p/u
hi ive lost a camera cable in a hotel when plastboarding was done, i have a fair idea but dont want to bust holes and guess..
ive been told a bt tone tester might help me, detect through the plasterboard ????
any help/ideas appreciated
a tone tester might help, but if the plasterers have buried the cable, get the hammer out.
The over 40M might be a problem if the transmitter's only battery powered (normally 9V), as it's not too deep in the wall then s/b able to trace it and find the end. Mine's either battery powered or mains powered from the circuit under test and on full power can detect up to 2M (have a read of the spec).
i generally find that one of these is great for finding lost cables behind plasterboard.
Ours cost about £120 , but that was about 9 years ago now . ( They have come down loads now !)
That one looks like it should do the job , just make sure that you can vary the generator output or it can just flood every circuits in the CU with a signal if you ever use it to find a mains circuit , also if you ever do need to find a mains circuit you will find it a lot more precise if the whole board is off and not just the circuit you are trying to find !
Cut a neat hole the size of a dry lining box. get the torch and fishing rods out and then when you eventually find it, blank plate will hide your terminations and bobs your uncle. Then take a hammer and introduce it to the plasterer, in the carpark of course!
DiLog cable finder from our friendly forum sponsor. Saved my bacon recently!
We use a tone tracker quite often but if there are alot of other cables in the walls the signal can be induced a wee bit.
CPC do some cheap options that are pretty decent. In a situation like this though i wouldn't bother with a tone tester and would definitely cut a 1/2gang hole and get th'rods out.
Wireless cameras can be handy but me and the lad at work just cut a 1 gang hole and stick the old smartphone onto video mode with the light on.
If i were you id cut a 1gang and use your phone to film inside then just pop a blank plate over, If your cameras going on that particular wall then you could use a 1 gang brush plate rather than a blank plate to bring the cable out. Just an option.
CLICK ME FOR TONE TESTERS
CLICK ME FOR BRUSH PLATES
i=p/u
Northern Ireland
United Kingdom
finding a lost camera cable
i=p/u,
Tidy Max,
