Fire alarm break glass | on ElectriciansForums
Discuss Fire alarm break glass in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
i=p/u
Northern Ireland
Have to move fire alarm break glass , don't know if enough length on cable,
do I have to use steel enclosure for connections if extending?
if I buy new surface break glass unit does it have to be same type, is there different types?
  • [ElectriciansForums.net] Fire alarm break glass
James Stuart panel, must be 20 years + since I`ve seen on of those......You will also need to protect the cable drop to the call point, any standard 470 ohm call point will work...As above galv 20mm trough box to terminate with crimps
Reply to Fire alarm break glass in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
HI, I'm a director of a freehold building which is 4 stories (one flat per storey), with a basement flat with its own separate entrance down...
Thanks Bennie. Yeah I have Oslo microwave sensor 2D type fittings which I was hoping to use. So permanent supply to all this would suffice? Thanks
