Fire alarm cert for extra smoke detector | on ElectriciansForums
Discuss Fire alarm cert for extra smoke detector in the UK Electrical Forum area at ElectriciansForums.net
South East Kent
Morning, do u need to produce a separate fire alarm cert for niceic if I am just adding an extra smoke to existing system. I understand if it was a new install grade D domestic then I would complete a full cert for that. Do I have to fill in a minor works like you do for an alteration to an electrical circuit?
As far as I understand when I last checked some time ago, believe it or not, Smoke/Fire Alarms are not covered under the IET Regulations unless part of a main panel.
Reply to Fire alarm cert for extra smoke detector in the UK Electrical Forum area at ElectriciansForums.net
HI, I'm a director of a freehold building which is 4 stories (one flat per storey), with a basement flat with its own separate entrance down...
Personally I won't do fixed price work unless there is a clear spec for the job including things like smokes, data, TV whatever else the customer...
Recommended Sponsor News
Hi everyone,
