Fire Alarm Compatibility Question? | on ElectriciansForums
Discuss Fire Alarm Compatibility Question? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
-Matt
England
Guys firstly i don't do a whole lot with fire alarms, i do the odd basic one here and there.
When i have done systems, i always use the same manufacturer/Model throughout the system.
A mate has asked if i can add an extra sensor, sounder (preferably combined) and call point to an existing Honeywell system. There is a spare zone free in the Panel (its a 2 zone panel with just 1 zone used at the moment).
The honeywell sensors don't seem available, so is there any issue using a different manufacturer or model of sensor or sounder?
Thinking about it i can't think of a reason it won't work?
Anyone any advice on this, as to if any issues mixing manufacturers of fire alarm components?
Cheers
I would contact Honeywell for compatible devices. Must be a rudimentary layout for one zone, why utilize the spare zone?
Most automatic smoke/heat detection devices are pretty generic in their operation and the biggest issue I see is the new sounder tone not matching the existing units.
if you are considering acomb ined detector/sounder, make sure the system is designed for such. i.e. is it a 2 wire zone including sounders, like savwire?
Reply to Fire Alarm Compatibility Question? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Just an heads up here, any expansion or addition to the control system of a Fire Alarm should be suitable for the job in hand and I don't mean...
Darkwood
Personally I won't do fixed price work unless there is a clear spec for the job including things like smokes, data, TV whatever else the customer...
