Fire alarm detectors-lighting | on ElectriciansForums
Discuss Fire alarm detectors-lighting in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
gazdkw82
leicester
I'm getting rid of the 2 fire alarm detectors and putting some new mains powered ones.
I'm going to take it off the light fitting in the living room and landing. How's best to do this on a plastered ceiling? Work around the joists and get a t+e through? Might seem an easy question but I've never done a fire alarm detectors before.
On that note, any recommendations for a detector?
Are you talking smoke / heat detectors Gaz? Can you not just come off the nearest light fitting? or is your intention to form a new circuit for these detectors?
Upvote 0
They won't be interconnected if you take it off 2 separate lights, you will require a 3core and earth between the detectors
Upvote 0
Domestic property. It's my house :)
I'm talking smoke detectors.
Do they have to be linked?
They don't have to be linked, or even mains fed. You have options for interlinking too with either hard wired or radio linked.
My personal preference is Aico as a brand, and I supply the 160 series for customers which have a 10 year sealed lithium rechargeable battery.
Upvote 0
I want to have them mains fed.
I planned to take the downstairs one from the living room ceiling Rose and the upstairs one from the upstairs landing light rose
If interlinking with a cable then you only need one detector to be powered as the power to the others is supplied by the interlink cable. If using two independently fed detectors you could wirelessly interlink them.
Upvote 0
Reply to Fire alarm detectors-lighting in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
HI, I'm a director of a freehold building which is 4 stories (one flat per storey), with a basement flat with its own separate entrance down...
Hi I'm again struggling with a long overdue 2396 project but, as before, am at a standstill when it comes to the lighting design. Please could...
Electrical Courses
