C
chubbs
Does anyone know if there is anything on the market that would allow me to wire a conventional fire alarm system in a stable and then connect a sounder to the owners house via a radio link?
Discuss fire alarm in a stable in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
what id do is fit a menvier radio tx (model 703r) next to the fire panel,use the fire relays to trip the tx,the tx can be powered by batterys only or just fit a small 12v psu,the rx (model 762r) would go in the house,you will need a small 12 v psu to power this,it has built in op's to fire a sounder,depending on how far the house is away the range should be fine,if not fit a high gain antenna,and as rock says no internal sounders in stable blocks,fit an external sounder strobe for local indication
If this stable is a dusty environment, the clients need to be made aware of the high occurance of false alarms from optical and ionisation heads. Iv'e have had loads of problems on existing installations all cause by dust contamination. Some manufacturers make heads that are designed for such conditions, obviously a little more expensive than the standard heads....
Not sure if R of R units are appropriate in wooden structures. I guess it depends on how well the structure is insulated, especially the roof...
smokes wont work,will fa too much which will end up with the panel getting down powered,fixed heat will be a risk as stables tend to be cold draughty places so you cant rely on it reaching a fixed temp,so its ror for me,and id double the protection to compensate for the conditions.
Well you could always go for infrared beam type, lol!!
Just a tad on the expensive side! lol!! ...:juggle2:
Reply to fire alarm in a stable in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
