Fire alarm panel and batteries inspection | on ElectriciansForums
Discuss Fire alarm panel and batteries inspection in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
F
FolgateSafety
Hi guys,
This is only my 2nd post on the forum, however I have been using it for the past 12 months to help me with various alarm, emergency lighting and PAT queries, keep up the good work and thanks !!!
I have a small fire safety company, which I use a sparkie to test the fire alarms and undertake any electrical works.
When testing a fire alarm I activate all the detectors, call points, check sound levels etc and my subbie check the fire alarm panel.
He does the following:
- visual of panel / clean dust
- checks battery dates and voltages
- voltage drop
- monitors the panel when mains is turned off and under fault conditions
Thing is, he charges me a fortune for under 30 minutes work.
I have a reasonable knowledge on fire alarm systems, what is stopping me from buying a multimeter and reading the fire alarm panel manufacturer's manual and undertaking the specified tests on panel and call points ?
Can I have some guidance please as I don't want to electrocute myself or endanger others!!!
Many thanks in advance guys
Dan
Folgate Safety
www.folgatesafety.co.uk
Reply to Fire alarm panel and batteries inspection in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
D is the negative for the SAB hold off supply In the bell the 0v is linked to one side of the tamper switch and then the other side goes back to C...
These keypads are obsolete and replacements are hard to find, I've replaced loads now with failing displays. Sounds like something isn't...
