Fire alarm question | on ElectriciansForums
Discuss Fire alarm question in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
DPhilpott
Hi guys,
I've fitted a fairly standard fire alarm system and commisioned it.. All fine. Customer has a window they would like to be opened to vent smoke in fire situation. The panel has the auxilliary switches. Is it going to be possible to run a standard 24v window actuator(powered from its own source) through the fire alarm relay? Thanks guys
opening a window in a fire situation could fan the fire and make it spread quicker.
Well i pointed this out... Fire brigade open door on ground floor and window opens on top floor (communal hallway) = bigger fire. Customer spec though. Although, that does create a new question.. Do i mention this on my fire alarm cert?
its better to vent in hallways etc imo,can help make exists easier and the fact its the smoke that kills more than the fire,tho i presume the spec has been ok'd by the insurance co,tho as you say ask the fire officer he holds the power.
This one comes up so many times, Ok local authorities usually require opening of vents stating smoke is the biggest danger. So before you do anything get approved conformation.
Best method in any case is to fit 3 way vent switch stating "off" "auto" "on" its a simple wiring job using off the shelf boxes and switches from local electrical wholesalers.
The idea of this method is when fire brigade are on site the can close vent until fire is out, then vent the smoke from building. If you need any wiring details just ask
That sounds like a reasonable option. Can i then make a standard 24v actuator do this? Or do i need the one with seperate relay etc? The switches on the panel are dry but i can run a supply from db if its going to work correctly?
Thanks again
You need check the current draw from actuator, should only be 40ma at 24v.
Most fire panels have aux 24v outputs rated at 1A so you should be able to used aux to power it.
I have attached wiring diagram which might explain. [ElectriciansForums.net] Fire alarm question
Reply to Fire alarm question in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
HI, I'm a director of a freehold building which is 4 stories (one flat per storey), with a basement flat with its own separate entrance down...
Just an heads up here, any expansion or addition to the control system of a Fire Alarm should be suitable for the job in hand and I don't mean...
Darkwood
