Fire alarm regs for re-wires. | on ElectriciansForums
Discuss Fire alarm regs for re-wires. in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Leeds
Can anyone clarify whether it's mandatory to install a wired interlinked smoke alarm in a fully refurbished house?
There is a wall coming out between the kitchen and dining room with new patio doors leading outside. I'm led to believe that a fire alarm is only mandatory if the escape routes are being changed, so with the wall coming out this could classed as the escape route changing?
Cheers.
Avoid LABC like the plague, they normally send the spotty freshly graduated kid out who seems to think they have all the answers and barely even know what BS7671 and the BYB is.
Your refering to a “smoke alarm” install not a FIRE ALARM.
If LABC are involved and spec it it has to be done if not always a good suggestion to the customer, if they dont have to have them some will some wont.
Thought if a heat detector is involved it wouldn't be a smoke alarm.
I have suggested to the customer that it is a good thing to have, was just wondering what the official LABC line was.
any structure changes in kitchen and the walls of Jericho came down
smokes right through the building .
As per my original post, I have been told that you only need them if the escape route has changed. Just wanted more clarification.
Yes but you didn’t say who you had been told by, it could be a talking dog for all we know.
If LABC have confirmed in writing that smoke alarms are not required then they are not required.
However, as has been previously mentioned, not having good quality smoke alarms installed to a good design is just plain daft.
Reply to Fire alarm regs for re-wires. in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
HI, I'm a director of a freehold building which is 4 stories (one flat per storey), with a basement flat with its own separate entrance down...
Thanks Bennie. Yeah I have Oslo microwave sensor 2D type fittings which I was hoping to use. So permanent supply to all this would suffice? Thanks
