Hi all, this is just a question to put my mind at rest and to see if I'm right. I'm not a qualified spark and I'm not the person(s) involved with the work.... OK here we go!
My workplace (large Plc) are having the staff toilets done up a bit. A hand dryer was removed from the wall and chase made for the cable that was in a conduit.
Got to work one morning (contractor working nights.) Wall had been clad over, out of the hole where dryer to be fitted a nice loop of what I'd call pyro!! (We are also having the fire alarm worked on.) obviously I immediately know the alarm won't be going there!
So why use an off cut of this to hard wire in the hand dryer?
I think the red cable is PF200? Its made up of red outer jacket, metal clad then 2x 1.5mm in a Rubery low smoke jacket and a steel earth or PC.
So is that right? I'd say no, and it should be PVC twin and earth 2.5mm.
Our fire cable runs out of a fused spur with a 13amp fuse fitted.
Photos included and any views greatly appreciated. Thank you all.
