B
bobby101
hi all doing a test for a property that has been fire damaged but when i tested all the white goods all failed 4 out 5 appliances failed on earth continutiy a little suspect yes i know but i did double check meter and leads all appeared ok the final appliance failed on earth leakage is it possible that my meter which is only a year old (metrel pat unit model number, cant remember) anyway the tester is pretty much kept in the van what is your views ta
