Fire Detection Certification. | on ElectriciansForums
Discuss Fire Detection Certification. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Spudnik
Morning all,
Due to start a rewire soon and one thing that has me stumped is this.
Client wants to install his own security & fire alarm combined system.
Basically, its a standard security alarm with the options of installing fire detection components.
I am not entirely sure how this should be certificated if at all? Do i just carry on without worrying about it?
I know we are not "obliged" to install any fire detection on a rewire.
Any pointer appreciated, to save me calling the "helpline".
:D
This is an interesting question that has had me thinking on the last few jobs I've been on where the alarm company has installed a fire alarm system .
As I see it smoke detectors wired in alarm cable back to a panel do not comply with bs5839-6
It's installed as a grade B system but it is not wired in fire resistant cable and it can't be a grade D system as there are no smoke alarms.
I think the best way is to wire a grade D system ie interlinked 230v smoke & heat alarms, with a relay base on one of the smokes and run a pair back to the intruder alarm panel.
Reply to Fire Detection Certification. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
ESP - https://www.espuk.com/# is the company you are referring to part of Scolmore
