Fire detector options | on ElectriciansForums
Discuss Fire detector options in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
gazdkw82
leicester
The fire alarm in the hallway is to sensitive when cooking. It's old and needs changing anyway. It's a mains voltage smoke alarm.
I plan to replace it
Definitely change to optical...
Ionisation sensors use a small radioactive source to detect the invisible smoke particles given off by fast-flaming, clean burning fires such as bedding and clothing, however they can be prone to false alarms from cooking fumes if fitted near kitchens.
Optical sensors use an infra-red beam to detect smoke. They detect smoke from slow, smouldering fires such as electrical fires & are less prone to false alarms from cooking fumes if fitted in the hallway next to kitchen.
Reply to Fire detector options in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
HI, I'm a director of a freehold building which is 4 stories (one flat per storey), with a basement flat with its own separate entrance down...
This is it though…. To put one following the letter of the law, so to speak… would be a smoke in the hallway outside the bedroom door… then a heat...
