Fire Hood Advice | on ElectriciansForums
Discuss Fire Hood Advice in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
C
chrisgc
Hi
I am installing some ip rated downlights in a shower/bathroom.
The void abouve the ceiling has loft insulation.
Do i need to just clear the surrounding insulation of each light OR do I need to place fire hoods over each light?
Chris
fire hoods not necessary unless separate occupancy above. clear at least 6" around each fitting.suggest hear resist. flex for connection to fittings.
Agreed, if there is a separate accomodation area above then this is a fire compartment and you would breach it.
As it is, a traditional house is 1 compartment due to the big hole between floors known as the stairs so no obligation to fit fire-rated or fire hoods however the choice is yours.
Reply to Fire Hood Advice in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
K
Advice needed - questions before getting new bathroom fitted Hi all, hope this is okay to post. Just over a year ago, I took on my dad's old...
KamikazeBob
K
  • Poll
Hi Folks, I'm looking for downlights that satisfy the following criteria: (1) white bezel; (2) fire-rated; (3) IP65 or above; (4) anti-glare...
