Fire rated access panel - can I avoid? if | on ElectriciansForums
Discuss Fire rated access panel - can I avoid? if in the UK Electrical Forum area at ElectriciansForums.net
London
Hi wonder if anyone can help
Can I avoid using very expensive fire rated access panel (and just use non fire rated access panel) if the electrical connections behind the wall access panel are in a fireproof connector (metal box) with fireproof gaskets?
Reply to Fire rated access panel - can I avoid? if in the UK Electrical Forum area at ElectriciansForums.net
ok cheers for the help lads
