Fire valve external oil boiler We have an external grant vortex pro and the fire valve is on the oil supply line 1.4m away from the boiler . Read somewhere should be a distance of minimum 1 metre away .
The sensor end is clipped into clip above the burner correctly . Just wondered if the fire valve should be closer or if that’s ok at 1.4m
Thanks .
Fire valve external oil boiler to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Thanks .
