Has anyone got these to actually work?
I got given 3 to fit today. I normally use AICO but have often wondered about these ones.
Mains powered, plenty of space inside, all looking good.
Instructions say to press learn button on each device, turn mains on, and fit detectors.
All was going according to script at this point.
Then I tested them.
-Kitchen also sounded Top of stairs but not Bottom of Stairs.
-Bottom of stairs also sounded Top of stairs and Kitchen (correct result)
-Top of Stairs also sounded Bottom of stairs but not kitchen.
So I "Unlearned" them (press button 9 times) and start again.
Same result.
Phoned support who said to learn them again, their final words being "good luck", and they were basically just reading from same manual as me.
At this rate the only place they are going is back to the wholesaler. Unless there are any tips or tricks anyone knows!
(There are plenty of YouTube videos which AFAIK apply to a different product range and have a different learning procedure)
Then I tested them.
Same result.
