SKY
Finally got around to changing over my consumer unit from a older Wylex single RCD unit to a new Dual RCD unit.
Will be using this install as my Elecsa Assessment on Monday.
My board is in the cupboard under the stairs.
Loving the snap in Crabtree busbar. I have seen this before in Ireland on a Siemens 3 phase board but first time I had seen it on a domestic.
Will fit Crabtree in future.
Old Board off and batten up
New Plasterboard with cut outs
Board Mounted
25mm Tails In
Ins Res Testing
End To End On Ring
Continuity Of Ring
Reading at sockets
End Of Day 1
Start of day 2
Lunch time day 2 - fitted a light in the cupboard on its own feed opposite to the ground lights side of the board.
So if that side goes you will still have light above the consumer unit
Batten up and plaster board in the cables
Finished - Just got to finish testing, cover up and label.
ZE
PFC
Have done lots of 3 phase Merlin boards in work on the shop floor but this is my first domestic.
On side 1 I have
1= Shower
2 = Down Ring
3 = Outside Socket
4 = Up Lights
5 = CU cupboard Light
Side 2
6 = Kitchen Ring
7 = Up Ring
8 = Boiler Radial
9 = Down Lights
Board Mounted
25mm Tails In
Ins Res Testing
End To End On Ring
Continuity Of Ring
Reading at sockets
End Of Day 1
Start of day 2
ZE
PFC
On side 1 I have
1= Shower
2 = Down Ring
3 = Outside Socket
4 = Up Lights
Side 2
6 = Kitchen Ring
7 = Up Ring
8 = Boiler Radial
9 = Down Lights
