First fix wiring advice | on ElectriciansForums
Discuss First fix wiring advice in the UK Electrical Forum area at ElectriciansForums.net
Peterborough
Hello, I've just joined this forum as I am hoping someone could help me out with some advice.
My parent's in law are renovating a cottage and have asked me to basically project manage it as they've had some pretty bad experiences. I have very limited knowledge and experience in construction apart from my architecture part 1 degree (so I am not totally crazy taking on this project). However, please do be mindful that I know nothing about electrics.
I've taken it on and I am trying to make some sense of the first fix electrics that has gone in. I was following the wires around to see where the plaster board could be placed and cut wholes for the second fix etc. However, I found that a number of wires had been fixes along the joists but didn't connect to anything, it would just be one end coming down one wall and one end at the other wall opposite...? Could anyone tell me why the electrician may have done this, is this common practice or was this a mistake? Should I plaster over the wires and leave the ends where the are at socket level?
Thank you in advance for your advice,
Veronica
Veronica
Hi Veronica, welcome to the forum. If you google prescribed zones then you will see how cables should be run.
LMGTFY - http://lmgtfy.com/?q=Prescribed+zones
Maybe post a few pictures so we can look.
Wires running up one wall and down the next sounds normal for first fix. Cabling dmfor a socket circuit would start at the Consumer unit and run to the first socket and from each socjet to the next (and often from the last socket back to the CU to form a ring. A similar thing will happen with the lights with power either run from light to light or switch to switch. Have the electricians fixed back boxes at the end of these cables? If so, plaster around them but leave the boxes open and not filled. Plasteres should no what to do here (but often fill the boxes which will annoy the electricians come second fix)
Its probably worth having a quick chat woth the electricians to check they have finished first fix, find out if theres anything they still need access to, and check theyve fitted everything that your in laws require and in the correct locations.
Veronica, You say your in laws have had some pretty bad experiences, they have therefore asked you to project manage a renovation despite you having no experience!? From your post it sounds like you are about to have a go at plaster boarding and plastering. I see a bit of history repeating itself here and them having another bad experience unless you ask the person who ran those cables to let you know why they are there and what they are for!
Thanks Shaun1, this is immensely helpful. I think you’re right - must be part of a ring (just learnt what they are so thank you!). Slowly I’m learning :)
Welcome , considered you are projected the job ,maybe you should ask the spark in what order he is doing the job considering your inlaws are paying for the work. .
The possibly the spark will tell you
It very hard trying to think sitting miles away thinking for you .
Each spark has a different way of working and putting in for the first fix .
in the end if you are not satisfied
You can always tell him.
If you know what you are talking about that is.
Reply to First fix wiring advice in the UK Electrical Forum area at ElectriciansForums.net
Live wires under floorboards? any years ago, when my daughter was just a crawling stage, we were having a new carpet fitted in an upstairs room...
M
Bathroom first/second fix plumbing costs Hi all, I just got a quote for bathroom and WC plumbing LABOUR only first and second fix ÂŁ3850 for the...
midaslegend
M
