SMA Sunnyboy inverter should be mounted on fire proof board. NIC guy pulled me on this when I was getting accreditation. A square of fire proof plasterboard should do the trick.
My gaffer wants an isolator before and after the meter in case you want to work on the meter??He's a strange one.Got to keep him happy you know how it is.Never heard this about inverter?Did he mention a reg?Do these things produce alot of heat out the back?i presumed the fan would do its job
edit:I'm on the non RCD side don't panic.Read up a good bit before i got stuck in
the need for fireproof board is debatable, as is a lot of NICEIC says!
If thats a partition wall though you may find vibration an issue. If it's a brick wall then just remove the board from behind the inverter and that negates any debate about fireproof board.
This actually made me laugh out loud. I suppose he puts an isolator between each socket on a ring main too?!
Nothing wrong with putting the extra isolator in - I just don't think it's needed. If the inverter is close to the CU then one isolator (lockable in off position only) will do it.
