F
floydyboy
Hi all, my first post on this forum. Im a member on the VXR forums and the detailing world forums, so if anyone is on either of those, give me a wave ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Anyway - I have recently moved into a house build in 1962. The electrics are pretty up to date, and a new CU was fitted a few years back to update the old one.
I am in the process of adding a few sockets to rooms that only have 1 socket. I have been doing this by spuring off the original socket in the room, and only having 1 socket per spur (as I know this is the safest way of doing it.)
My question is. I am going to run a socket into the small bedroom off another socket in the Main bedroom. Im doing it this way as the placement of the new socket is directly behind the existent socket in the main bedroom (drilled through the wall).
On the original double socket, I am currently running an xbox, tv, bluray and the sky box.
If I run a spur off that double socket, can I use the new socket as normal, or am I overloading the circuit as I will have so much stuff running off that one area. I am only going to use the spured socket for a desk lamp, and nothing else.
Thanks for any help that is given!
Lloyd
Lloyd
