First/second fix | on ElectriciansForums
Discuss First/second fix in the Australia area at ElectriciansForums.net
davejp
Hi all, just a quickie..
I have heard the phrases "first fix" and "second fix" a few times, what is meant by first/second fix?
Thanks in advance
Dave
First fix, put in cables back boxes etc.
Go away, let plasterer and plumber do their bit.
Second fix, (repair the damaged caused by other trades) put on accessories and CU, test, cert and run with cash!
Briefly, in a new build first fix is putting the cables in place, then you get the plasterers in etc then 2nd fix is putting all the sockets, switches, fittings etc in.
edit : i'm just so slow at typing !!! :eek:
Plasters can sometimes damage cables, you need to make sure they are tucked away nicely in the back boxes or the trowel can rip into the cable (only if they are inconsiderate and in a rush).
Plumbers like to drill into cables or even burn them with the blow lamp!!
the way things are nowadays and if you dont know the other trades and wont be around on site when they are, take photos of exactly how you left the installation.
Should there be disputes and the person ordering the work is a decent chap, they will reclaim remedial work costs from who did the damage.
Unfortunately one has to cover ones backside.
With new build work I try to leave a cable end stuck out of the box as I had one job where the plasterer plastered everything flush with no indication where all the boxes were also tend to make it known that I will be on the warpath if they cut the cables to suit their needs after being left with an 18 gang switch with all the markings cut off when the cables where shortened because the plasterer didn't like plastering round boxes with too much cable hanging out of them
Reply to First/second fix in the Australia area at ElectriciansForums.net
M
Bathroom first/second fix plumbing costs Hi all, I just got a quote for bathroom and WC plumbing LABOUR only first and second fix ÂŁ3850 for the...
midaslegend
M
If you have a UTR then you must have applied for it so it should be fine unless anyone knows different. Did you register through the CIS scheme...
