Squid_uk
Hey guys!
I am after some advice on quoting for my first domestic job for a contractor (I have only done jobs for friends who were happy for day work).
I have been asked to quote for a small external domestic boiler room (3m x 1m). The plan is that the boiler room is to be knocked down (currently blockwork room) and rebuilt (timber) and firewalled inside.
The room currently has an oil fired boiler which provides heating for 4 small flats and 1 circulating pump.
I have attached some pictures to show you whats going on in there at the moment.
From what I can tell is there is a ring main that has been broken into (old grey sheath T&E inside the double surface box with a blank faceplate) to supply the FCU. Inside the box is also a spur to an old style single fuse board. The fuse board (left) is live but has no outgoing wiring. There is also a 2nd fuse board (right) which again is live but has no outgoing wiring. This 2nd board appears to be fed from a cable coming down from the roof space of one of the flats (have not got access into either flat to investigate further as of yet ).
So back to the FCU, after the FCU is a private meter, I belive this is used to divide the cost of oil between the 4 flats. From the meter we come to a time clock, then into a joint box which connects the boiler and circulating pump. All wiring described and pictured is 2.5mm T&E.
The job I am quoting for is to isolate and remove all electrics inside during the demolishing stage. And once the new building has been completed, installing a new wiring system, which will more than likely be a plastic conduit installation.
What kind of price do you think would be resonable (I usually charge £20 per hour labour).
Thanks for your time in advance!
