N
nickblake
Been to a fish farm they need to replace all their lighting ,at the mo they have 6ft twin vapour proofs on chains , but due to the high humidity and salt , the fittings twist and the fill with water ,also the installation methods were no great ,they want all the fitting mounted at a lower level for ease of maintainance , so my idea is to use the starlux metal halide 100 watt bulk head fitting ,use stainless steel scres and the lid screws coat with silicone grease , the salt is unbelivable in this place and it literally on the coast by the sea too so any metal fittings are out of the question , they have big pumps with inverters which the inverters need removing and cleaning every 3 months just to remove the salt buildup from the atmospher ,any thoughts chaps
