M
Mark1
Hi. I am trying to fit a replacement pendant light fitting on a like for like basis. Sounds simple, but the new fitting is from Next, and the instructions state that I should use the in line connection block supplied, lining up the wires using the usual colours. Unfortunately, there are three wires in clear plastic sleeves, and a further earth wire from the ceiling fitting. How do I know which wire to connect to which ? Any advice would be gratefully received. Thanks, Mark
